Using Winrar, I extracted multiple .rar files and it created a .bin and a .cue file. Now I have to different folders, in each of them there is a .bin and a .cue file.
What I'm supposed to do next to execute these files?
Thanks in advanced.
Results 1 to 10 of 10
Do I have to burn to CD or can I burn directly to a folder within my hard drive?
Thanks -
You can use an app called Daemon Tools to emulate a dvd-rom and then you can just browse your .bins
Nothing is impossible for DiLeMmA says so!
See my guide on how to batch author dvds!
https://www.videohelp.com/forum/viewtopic.php?t=255213 -
you can burn a .bin file WITHOUT the cue file in Nero, but you need to know if it is MODE1 or MODE2 before you do so....
So there is no way to burn this bin file to a folder within the hard drive?
Or convert the file to something else that can be played from the hard drive?
Thanks, -
actually there is, and dilemma sorta pointed it out in a manner that i could not have beaten. load it up into daemon tools, just to reiterate.
Thank you for the help, is now working with the Deamon Tools. I just didn't know how to use it.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
