hi,
im having a problem with the final dvd image and i havent quite managed to find a solution.
after ive encoded my avi. file and have my video_ts and audio_ts folder, i test it on apple dvd and it plays fine, then i burn my dvd and it plays without a problem on my external dvd player. however, on the external dvd player, once the movie plays faster images/sequences ie; running, fire, action - basically any kind of fast moving images the video playback stutters and wont play smoothl, until the shot pans out and the action on screen is slower.
is this a sample rate problem?
thanks for any help
It may eventually be a bitrate problem. To determine it, encode a clip of the same material with "DVD mpeg2enc" and check if it plays better (I assume you encoded that one with "DVD ffmpeg").
Problems with turning image sequences into movie files for timelapse?
By adam-tl in forum MacReplies: 26Last Post: 2nd Dec 2011, 06:05 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 13:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 14:26 -
problems with video image settings
By BDawg in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2007, 18:50 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29
