I created an ISO file and when I tried burning the DVD using DVD Decrypter it gave error after 82%
I tried again with other disk and again same error same place..
I ran a test run and it went fine...
created the ISO file again using DVDShring and error came again this time some other place..
Used FILE shrinking and used NERO to burn DVD got the error...
Can anyone suggest what should I do to resolve this ??
TIA
What type of media did you use and at what speed did you try to burn at?
I used TEON 8X and burned with 8X speed..
I have burned 3-4 DVDs before this one and they all went fine.. -
Not sure what the media code is for the Teon DVD's. I would reboot and try burning at 4x. It could be the media your using is a low quality media. You can goto www.nomorecoasters.com to check the different media codes.
Enchanted error (DVD Decrypter)
By rickygg in forum DVD RippingReplies: 1Last Post: 4th Apr 2008, 09:39 -
DVD Decrypter error
By turbochargedRS in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 19:08 -
i/o error in DVD Decrypter
By msdker in forum Newbie / General discussionsReplies: 18Last Post: 20th Dec 2007, 22:03 -
DVD Decrypter error
By tRAVALO in forum DVD & Blu-ray WritersReplies: 6Last Post: 26th Aug 2007, 11:10 -
Error with DVD Decrypter...
By hiimbored in forum DVD RippingReplies: 29Last Post: 4th May 2007, 20:37
