I'm a newbie and want to convert Divx to SVCD. I followed the guides on vcdhelp.com, loaded up the divx and the appropriate template. Hit 'Start' in TMPGEnc, and it tells me 'An error occured when audio was decoded'. Tried the alternative methods, LSX-MPEG, and CCE but newbie me couldn't figure them out...
Here's the stat/info on the Divx, that I got from VirtualDub:
576x240, 23.976fps
1:33.09 long
48000Hz sampling rate
Channel:2(stereo)
My newbie mind tells me the 48000Hz sampling rate is the culprit but how can I fix this? I separated the audio and video track like the CCE foolproof guide on this site, and CCE disappear(crashed?) right after I add the .vdr file. Anyhow, I used the separated audio and video track in TMPGEnc, loaded SVCD template, and started encoding without problem. Resulting mpg has sync problems tho... can anybody help?? Thanks!
Results 1 to 1 of 1
TMPGEnc Authoring Works 4 problems...
By gonzalo76 in forum Authoring (DVD)Replies: 7Last Post: 12th Oct 2010, 01:59 -
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 12:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
