Hi , I guess what this value is about because I've muxed with ffmpegX a divx (xvidffmpeg preset) file with ac3 audio and I can't hear any sound with VLC or QT(ac3 and divx component installed). Then I muxed the same two files wit D-vision 3.0 and it worked.
The only difference is about the sample value in the audiocodec info, which is -0 for the file muxed with ffmpegX and -2 for the file muxed with D-vision.
Any idea?
Results 1 to 1 of 1
does ffmpegX accept wmv as input?
By mark909 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Sep 2010, 14:02 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
Digibeta Deck as source input for FFmpegX
By reelrootsryan in forum ffmpegX general discussionReplies: 0Last Post: 18th Nov 2008, 17:48 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
How to make a sample of an AVI file pls?
By incrediblej in forum EditingReplies: 5Last Post: 20th Dec 2007, 08:59
