Results 1 to 10 of 10
  1. Anonymous
    Guest
    whats the best and fastest program to do a 1:1 copy, nero randomlly likes to freeze at like 100% any ideas? Thx
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    for DVD-5, or DVD-9 to DL:
    DVDDecrypter ISO Read > ISO Write
    for DVD-9 to 2 DVD-5s:
    VOBBlanker -> DVDShrink (no compression) -> DVDDecrypter
    If in doubt, Google it.
  3. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    1:1 copy:
    DVDDecrypter
    just like jim said
  4. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    as above
  5. Anonymous
    Guest
    I don't have to rip it first do I? thats whut i'm trying to get around..
  6. Member archaeo's Avatar
    Mar 2004
    mountains
    uh oh, another 'best' post...
    that said nero 5.5 has always worked for me.
    just be sure to set the write speed lower than that of the read speed. Otherwise you could end up with errors.
    Dec 2004
    Canada
    doesnt he just mean exact copying not dvd drive to dvd drive.
    COPIED OVER 600 DVDS SO FAR
  8. Originally Posted by mattyboy
    I believe he means both.
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  9. Member doppletwo's Avatar
    Dec 2004
    United States, Earff
    No he doesn't want a rip step.
    He just want to do it like the nero quick copy option.
    Can Decrypter save onto a DVDR?
    I have never tried it.
    He should just rip and burn as this is a more reliable method.
    snappy phrase
    I don't know what you're talking about.
    Sep 2003
    Your profile does not indicate a DVD ROM drive, so to copy a dvd, you first have to transfer it to your HD.
