In dvd2svcd there is a frameserver setting that has a section on how to edit borders with avisynth but I can't figure out how to do it.
It has something like this
0=bicubic resize ^width^height^b_value^c_value
1=add borders ^ " " " "
^b_value=
^c_value=
Something like this. No matter what I do the borders are always there. -
could be that even though ur goign anamorphic you've got super widescreen source (ratio greater than 1.77:1) in which case you need the black bars to maintain the correct aspect ratio
I've converted 4:3 avis and dvd2svcd always adds border for me as well.
I bypass by selecting "Edit as part of video encoding" in the "edit the avisynth script file" section in the "frameserver" tab.
That way you get a popup of the final script before the encoder starts which you can alter.
A pain though cause you can't then batch.
Or you can press the symbol of the hand writing on paper on the right of the "frameserver" tab and change:
0=LanczosResize(^TargetWidth,^TargetHeight)
1=AddBorders(^BorderLeft,^BorderTop,^BorderRight,^ BorderBottom)
to something like:
0=LanczosResize(720,480) -
Once I edit the script with Frameserver,which do I have to check
"No editing"
"Edit when avi2dvd is done"
Thanks -
'No editing' would be preferable however it could be beneficial to try 'edit as part of video encoding' once to see the script and make sure all is as you want.
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 09:29 -
Avisynth Script Help
By jamhat in forum Video ConversionReplies: 2Last Post: 29th Nov 2009, 07:13 -
Avisynth script
By daz2712 in forum Video ConversionReplies: 2Last Post: 19th Aug 2009, 12:08 -
Software that export editing operation as avisynth script
By Nykoo in forum EditingReplies: 4Last Post: 3rd May 2009, 14:12 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 12:29
