Sorry for all these questions but I am new to this.
I have a avi movie 480x352. When I try to convert it to a svcd using DVD2SVCD I get borders at the side.
Can I resize the file to get rid of these borders and still have good quality?
If so how?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
I am not so fond of DVD2SVCD myself. But I know it worth testing in TMpegEnc cause there you will have better control to get a preview and everything and see what will be you eventual output file.
Try TMpegEnc
To fix the side borders with dvd2svcd click on the frameserver tab and choose edit as part of video encoding so when it comes to the part of encoding a menu will popup where you can change some of the encoding script such as borders.
For example if you see:
BicubicResize(340,480,0.0,0.6)
AddBorders(70,0,70,0)
then cut out the add borders and resize the 340 to 480 so you get:
BicubicResize(480,480,0.0,0.6)I think,therefore i am a hamster.
one topic is enough.
https://www.videohelp.com/forum/viewtopic.php?t=255044
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 15:47 -
[solved]3d side-by-side capture and conversion to anaglyph using VirtualDub
By jumpjack in forum Capturing and VCRReplies: 21Last Post: 13th Apr 2011, 19:23 -
How we can watch all youtube videos on fullscreen without side borders
By nusratjaveid in forum Video Streaming DownloadingReplies: 3Last Post: 9th Dec 2010, 10:38 -
Is the panasonic dmres46v a seudo svhs side-by-side player/recorder?
By yoda313 in forum RestorationReplies: 8Last Post: 17th May 2010, 08:09 -
Black Borders won't go away!!!
By mirandapanda in forum Newbie / General discussionsReplies: 6Last Post: 10th Sep 2008, 01:49
