I just purchased 50 injet printable Taiyo Yuden and my Nec DVD+RW ND-2100AD will not even recognize them, I brought in 1 sample Ridata and it is also not recognized but the Maxell I have give me no problem, could I have made a mistake buying 8x as the maxell are 4x. Thanks for any help I get.......................scotty47
The NEC 2100 is a +R only drive, are the TY and Ridata +R discs?
On a somewhat related note, I'd suggest you convert your 2100 into a 2500, which will enable it to burn -R media as well as giving you the option of upgrading to a better firmware. If you are interested let me know, I can point you in the right direction. -
Yes I just noticed I bought DVD-R. I would appreciate if you could direct me to upgrading, Thank you..........scotty47
let me know if you got it, I just sent it, not sure if it got sent though for some reason....
A question about Taiyo Yuden.
By wtsinnc in forum MediaReplies: 18Last Post: 13th Jan 2013, 04:03 -
Taiyo Yuden DVD-R's (In Australia)
By SE14man in forum Newbie / General discussionsReplies: 0Last Post: 20th Jun 2011, 03:21 -
Bad Taiyo Yuden discs
By StrobeLightEpileptic in forum MediaReplies: 61Last Post: 2nd Jan 2010, 18:30 -
Taiyo Yuden ... an omen of problems to come?
By AlecWest in forum MediaReplies: 20Last Post: 17th Jan 2008, 09:27 -
Taiyo Yuden DVD-R - Thanks
By casual-dvduser in forum MediaReplies: 3Last Post: 6th Jun 2007, 02:59
