I got the drivers loaded divix 5.02 and Lame. But each time I attempt to make a divx from a dvd I get a stack dump in the kernal or sometimes the mp4 vxd or just a blue screen. Tried reinstalling all in various order. I used the guide and made the settings the same. Did anyone have simmilar trouble with DVDx and work through it. I am a noob but have been making VCD using VCDeasy for some time now with no trouble.![]()
Hello,
If you can't seem to get dvdx working there are plenty of other dvd-vcd tools out there:
DVD to VCD
Found in the tools section under "LISTS" on the left of the screen <-------
Thanks Kevin for the get back,
I am mostly interested in DVD to DIVX conversion because it is so clear and the file size is small. My second reason for wanting divx is that I have a friend with an ARCOs multimedia drive and I wanted to find a one step DVD to Divx converter so he can watch movies in the car or plane. The info on DVDx looked realy good and Free!
Currently he has to make an AVI file or MPG then convert to divx. I am wondering if someone is using DVDx ver 2.3 with Divx 5.02 codec and Lame mp3 ver 3.92 in combination with good results or should I try other combinations of video and audio codecs to get DVDx to work. It probably seems kind of stuburn to try to fix the DVDx so I am open to other one step DVD to divix converters, any suggestions of good ones.
Making videos "for sure" playable in standalone player
By Meagain in forum Video ConversionReplies: 1Last Post: 29th Dec 2008, 16:39 -
Making a Toast "DVD Video" Disc
By albloom in forum MacReplies: 5Last Post: 22nd Apr 2008, 11:45 -
Re: making "live" chapter button with windvd creator 2
By tomcat862 in forum Authoring (DVD)Replies: 0Last Post: 28th Feb 2008, 12:13 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16 -
Which software do "DVDx" with batch encoding modes pls?
By amdk62 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2007, 05:39
