My Mother sent me her OLD A$$ Acer computer with Win 95 to backup her files and install Win 98. She only had enough files to use 6 floppy diskettes. No usb ports on this thing and no network card, and also no burner in it. I took the 6 disks from the backup of files and tried to copy them onto my XP machine and I get errors or I cant open them at all (A: tries to read and just hangs). I know my A: works because it will read any other disks I throw at it. Anyone have any idea as to what I can do besides add a ethernet card and network these two together? Any input appreciated!
If at first you don't succeed; call it version 1.0
XP may not like the way they have been formatted, especially if they are old.
I would try formatting the floppys on the XP machine then backup the files to them on the 95 machine.
They should now be readable on the XP box. -
The easiest would just be to pull the HD out of the old machine and attach it temporarily to your computer as a slave.
Sounds like you need to replace the floppy on the old machine anyway, maybe replace it and do the floppy transfer over.
You could also use the parallel or serial port for transfer, but that would probably be a pain in the ass to set up. -
ok...Ill give it a try and see what happens...BIG ty for the replies
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
