Badger -
You told me that you had a fix for the 64-character limit for svcd2dvd v.2RC1. I haven't heard back from you since, so I'm thinking that you haven't received the emails I've sent. In any case, I would definitely like the fix for this problem. let me know ...
John
I am unable to send out the fix for this as the development is "in between" releases.
So for the moment to avoid the "64 Char" bug, make sure your assets filenames are less than 45 characters. This is just the filename not the full path.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
EastEurupe character endoing
By michcio in forum SubtitleReplies: 38Last Post: 19th Jun 2012, 18:23 -
Matrix Character SubRip
By Anonymous171 in forum SubtitleReplies: 0Last Post: 7th Apr 2012, 19:38 -
MKV subtitle character problem
By ratatouille in forum SubtitleReplies: 1Last Post: 22nd Aug 2011, 04:43 -
dvd subedit turkish character problem
By siddharta in forum SubtitleReplies: 0Last Post: 28th Nov 2009, 20:44 -
Need good character generator
By tonynasc in forum EditingReplies: 0Last Post: 24th May 2007, 19:03
