i have 2 HD's, one that i have and one from a friend. the one that i have is the master and of course boots first. but when i set the one my friend gave me to slave it still botts first and says DISK BOOK FAILURE. can someone please help me? thanks![]()
some drives have a Master / Single Drive setting and Master in a 2 drive configuration. Check your and if so make sure the "master" drive is jumpered correctly for a Master in a 2 drive config.
Ensure HD Master is at the END of the IDE and the HD SLAVE in the middle...the end position has priority......(honest..its true).
And check your BIOS is booting the correct HDD first. -
You know that BBCode does not work in subject lines? No reason your question should be any more important than any other one...
As Ripper and Monzie say, check your hard drive is Master and the other is Slave. Ensure the boot order in BIOS is:
1 - Floppy
2 - CD-ROM
3 - HDD-0 (not HDD-1)
Cobra -
Cobra,
That is not a good sequence unless you boot from CD-ROM on occassion.
You will get stuck on a reboot if you leave a setup disk in the drive, "non-bootable drive" if you leave your Norton disk in the drive..
Cheers,
George -
George,
You're right - I do occasionally do that by accident, but it is more convenient than having to change the boot order in BIOS to CD first then back again every time you want to boot from CD.
It's just personal preferance, I suppose. Some people would prefer it one way, other people prefer it the other way.
Cobra
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Problem with hard drive
By jek in forum ComputerReplies: 4Last Post: 4th Nov 2008, 07:22 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06
