Well how are everybody doing, i'm new here but i read forums everyday, anyway i'm from venezuela and latetly had been hard to find dvd-r here, so i found some brands maybe u had burned those , this are the brands:
*SKC DVD-R 4.7GB single-sided 4x? is it good? it's a 25dvd-r spindle
*Ridex DVD-R 4.7 GB 4x, it's a 50 dvd-r spindle, is it good?
*V-MAX DVD-R 4.7 GB 8X, 50 dvd-r spindle? how about this v-max
*Ritek dvd-r 4.7 gb 4x, 25 dvd-r spindle, the famous g04, but latetly i've been reading that sucks, is it true?
*Matrix dvd-r 4.7 gb, 50 dvd-r spindle, 8x
And finally
*Optodisc 4x dvd-r, 50 dvd-r spindle
Hope can help me about this media, cause i need to know which is the best, cause here are really expensive, however i forgot to tell that i have a LG gsa-4120b drive![]()
Out of the choices you listed, I'd still have to suggest the Ritek G04's. I know some have had trouble, but I think that in the grand scheme of things they are still generally going to be decent discs, especially in comparison to the other options you listed. Optodisc is generally complete junk in my experience, Matrix is likely going to be something cheap such as AN32, which are of marginal quality. SKC I think are also cheap generics, don't even know what V-MAX or Ridex is (did you mean Ritek or Ridata?).
I'd just start out by trying a 25 pack of the G04s, if they work well then go from there. -
thanks man, no man those are the names, v-max, ridex
Look man the ridex ones:
http://www.mercadolibre.com.ve/jm/item?site=MLV&id=3268649 -
i found this gygabyte 4x dvd-r disc not printable, Gigablock 100 DVD-R 4x
[GB-RST4X] -
Do NOT consider the SKC DVD-R 4.7GB single-sided 4x. Having big troubles with this media in Australia.
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58
