I think I posted this before but can't find my posting. I'm redoing it again. My son is working on a video project. He uses his ATI TV Tuner captured a number of TV show using AVI format. File size ranges from 1.2GB to 5.8 GB. He was planning to use Adobe premirer pro to edit part he does not need. It was unfortunately that Adobe complains that it is "Unsupported format or damged file" for all of his captured avi files. However, there are successfully played in various player we have on our computer. We thought about converting it to MPEG and try. I downloaded a few conversion program and found only WinAVI works best but it won't convert file larger than 3GB. I then found an AVISplitter program but it won't recognizes the AVI file format.
Can someone please help me by suggesting me as what to do to get these AVI files into Adobe ?
Here are what I can think of to do for now:
1 - It is a good idea to convert it into MPEG ?
If yes, what tool I can use to either split or convert it ?
2 - A tool to fix the AVI files s.t. it can be used by Adobe ?
Please help. Any suggestion will greatly appreciated.
Thanks in advance
Results 1 to 9 of 9
Try Virtualdub to split, edit, and output something Adobe can recognize.
Cheers, Jim
My DVDLab Guides -
Hi Welliep53,
1. 1 - No, not if you want to edit. Better as AVI.
2. As reboot says. Try installing the Panasonic DV Codec and using VirtualDub to use that (click: Video -> Compression and select), and then save AVI.
Premiere works best with DV AVI I believe - that's all I use it has no problems / reconverting.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hi Welliep53,
try to slit your files with SolveigMM AVI Trimmer. It's free.
http://www.solveigmm.com/?Products&p=AVITrimmer -
The word "split" is nowhere to be found in Virtual Dub.
Is there anything else that will split AVI? -
Sheesh. point and click...(sorry).
Open the movie in virtualdub, mark start, scroll to your cut point, mark end. File, save avi.
Do the next part, etc.
You end up with as many little bits as you want.
It's free, it's not id10t proofCheers, Jim
My DVDLab Guides -
The instructions are more difficult to interpret than actually using the program.
Virtualdub is so versatile, and there are guides on how to use it. Click on Guides, and search for virtualdub. I'm sure you'll find more than one that can explain how to cut an avi, better than me anyhow
Cheers, Jim
My DVDLab Guides
SPLIT A LARGE VOB FILE INTO 1GB CHUNKS AND AUTHOR
By jimmalenko in forum User guidesReplies: 39Last Post: 12th Aug 2011, 09:37 -
Any advice on how to split a large AVI into smaller clips easily?
By Bluelude1 in forum Capturing and VCRReplies: 11Last Post: 19th Jun 2011, 11:55 -
Vdub script / tool etc - split large file into 10 min segments? (auto)
By Jynks in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2010, 06:19 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
large file split for multiple displays and convert ... what tool 2 use?
By rodpacker1 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 03:03
