Ello everyone, does anyone here know how to make buttons invisible unless when they are selected, Im using DVD-Lab Pro.
I have an image that i want to become visible when it is selected but remain invisible when it isnt selected, ive tried making it "invisible normal" but when i select it, its just a block of colour (the one its set to light up as), i dont want it to go any colour just appear when it is selected. can anyone shed any light on what to do here?
Thanks alot =]
All the best
Tom
On the Map tab, make sure you have #3 selected, and then slide the bar all the way left for #3.
This will become truly invisible, unless selected.
Cheers, Jim
My DVDLab Guides -
Just tried it but it still stays invisible, what should the button visibility be set at?
Thanks again =]
Tom -
I think you either have to make the image area's subpicture the same color as the background (background has to be solid for this), or the image itself has to be a very simple shape and not a multicolor graphic.
aye your right. the background isnt solid, but ill try making the button solid and see how i get on. thanks alot =] I once managed to do it using a square so maybe it will work.
All the best
Tom -
If you don't want it to highlight, just become visible, I think you will have to use switched menus.
GfD - Buttons invisible after creation on DVD
By michcio in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2009, 17:22 -
Invisible earpiece solution?
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd Dec 2008, 22:36 -
Creating buttons on a motion menu
By jrd3263 in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2008, 16:13 -
Why is my external burner invisible in DVDFlick?
By mavrickjubei in forum Video ConversionReplies: 1Last Post: 26th Mar 2008, 00:53 -
Creating highlights for buttons in Encore
By newsphotog in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 18:19
