when ever i click on a movie that is in the titleset layout i get this error and am unable to preview the movie
using rc1:-
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040218): Exception from HRESULT: 0x80040218.
at QuartzTypeLib.FilgraphManagerClass.RenderFile(Stri ng strFilename)
at x3284ccece41ee22b.x79ed6fa5f8db6479.x535825f93c028 407(String xa39af5a82860a9a3)
at x3284ccece41ee22b.xb6dca8349e33d934.x8ab0d03b11b82 1b8(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at DevComponents.DotNetBar.SideBar.93(BaseItem 331)
at DevComponents.DotNetBar.BaseItem.RaiseClick()
at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBarPanelItem.InternalM ouseUp(MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBar.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.SideBar.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.1843.19197
Win32 Version: 2.0.1843.19197
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assembly Version: 4.6.0.0
Win32 Version: 4.6.0.0
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.QuartzTypeLib.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
SVCD2DVDLib
Assembly Version: 1.0.1839.37055
Win32 Version:
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVDLib.DLL
Microsoft.VisualC
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.3052.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualc/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualc.dll
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Can you play the file in WMP?
The same thing is happening to me.
Im able to view the orig mpg with WMP, Power DVD, VLC Player. Im also able to view the dvd.mpg files that are created by SVCD2DVD without any errors..
I still have the original v1.5 installed as well as RC1.
If any solution can be found, would be great as I have to wait for the DVD to complete before being able to view the Menu etc..
Apart from that, what a great encoding application this is.. -
RiCoCheT: I think you are talking about menu previews where as this thread is on about the title previews...
oops, I am, ill post a seperate thread.. my apols..please delete my post on this..
no worries
Batch Processing 2.34:1 AVCHD Files for preview
By goanna300 in forum Video ConversionReplies: 17Last Post: 28th Jun 2011, 02:45 -
Xmedia Recode preview/save error
By fester77 in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2011, 07:25 -
Sony Vegas 8, files size preview?
By cshortt in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 11:25 -
Using Divx Preview for mkv support but no audio on some files...
By AndyD in forum AudioReplies: 9Last Post: 22nd Nov 2009, 16:25 -
receiving error message when trying to preview, can anybody help?
By hotmom25 in forum Newbie / General discussionsReplies: 8Last Post: 8th Feb 2008, 09:43
