In BSplayer or RealOne player
how do I switch from left to right channel???
Because I have some shows with dual language but it's in center channel so i hear 2 different languages
but i cant find an option to change the channels... is there a way to do this???????
RMVB, like everything from Real Networks, is retrograde. I don't know the answer to your question, but you could TRY using Real Alternative, which will allow you to use Media Player Classic to view .rm's and .rmvb's instead.
If you have Real player installed, then all you need is Media Player Classic, Real Alternative is not needed and could cause problems if installed over the top.
Ok then, don't install Real Alternative.
Better yet, get your media somewhere that doesn't require you to use horrifyingly bad software.
Need Help Changing the Default Audio Stream for Hundreds of MKV Files
By ballsoup in forum AudioReplies: 11Last Post: 19th Apr 2016, 15:53 -
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 10:07 -
Dual Audio in RMVB files?
By bAz666 in forum Newbie / General discussionsReplies: 8Last Post: 12th Feb 2008, 21:18 -
I've got a problem with some .RMVB files
By architectofpain in forum Video ConversionReplies: 6Last Post: 18th Dec 2007, 22:47 -
AVI files with 2 audio channels
By danjull in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 05:57
