When I try to cut svcd mpeg2 files with tmpgenc the program crashes. I can join files without a problem but not cut them. Is there something I can use other than tmpgenc to cut svcd files?
This is the error message I get:
"TMPGENC12 caused an invalid page fault in
module SDRENDER.AX at 017f:0204317e.
Registers:
EAX=00000000 CS=017f EIP=0204317e EFLGS=00010282
EBX=d0f69800 SS=0187 ESP=0201fe6c EBP=0201fe94
ECX=00000004 DS=0187 ESI=02420ffe FS=5df7
EDX=fffe3c02 ES=0187 EDI=d0f697fc GS=0000
Bytes at CS:EIP:
8b 06 86 e0 c1 c8 08 66 89 07 c1 e8 10 86 e0 66
Stack dump:
10040000 fe7cfe94 0004b98d 00001000 01338e80 01222d24 bff7b98d 00000004 d0f31000 d0f31004 bff7b9b2 0204a8cd 023b0006 00000000 00000004 01222db8 "
Try a newer version, as some of the 12X versions had a bug for Mpeg2 cutting
The Dutchman
Avidemux crashes with many, many MP4 files. How to handle?
By Diana (Cda) in forum Video ConversionReplies: 6Last Post: 5th Feb 2017, 19:55 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 15:32 -
TMPGEnc Xpress 4.7.4.299 crashes at 50%; audio related
By CasanovaFly in forum Video ConversionReplies: 0Last Post: 28th Mar 2010, 22:20 -
TMPGenc crashes when opening avi
By Kromgol in forum Video ConversionReplies: 4Last Post: 19th Jul 2009, 09:03
