im not sure if this is the right area or maybe i should be asking this in the dvd to dvdr area but i was wondering if there is an easy way to add the deleted scenes to the main movie. i know some are so low res that you would not want to added them to it but sometimes the dvd includes full res deleted scenes and im wondering why they just dont add them. weel if anyone has a quick fix i would like to try it but if it is really involved then i will probably learn it some other time. thanks though
Im not sure how to add them to a movie, but I will shed some light on why they dont just add them to the movie.
9 times out of 10, they are deleted scenes because they affect the "flow" of a movie. If you watch most of the deleted scenes from a movie, they do tend to be pretty boring anyway, hence why they are cut.
Thats from my knowledge base anyway.
LG -
I´m not sure, but DVDremake Pro should do it. But depends if the deleted scenes are in same aspect ratio and same audio format (ac3 5.1 usually) that the original has.
thanks lg... that sounds about right
and thanks db... i totally forgot out that. i will check dvdremake pro again
Converting DVD Deleted Scenes to MP4 - Subtitles Don't Match
By rickydavao in forum DVD RippingReplies: 1Last Post: 14th Mar 2012, 01:46 -
How to Add Deleted Scenes & make it complete version?
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 06:29 -
Combined DVD Movie with Deleted Scenes?
By Ghtpua in forum EditingReplies: 3Last Post: 25th Aug 2009, 19:34 -
Remaking Special Edition: Inserting Deleted Scenes
By snipper_cr in forum EditingReplies: 0Last Post: 16th Dec 2007, 13:45
