  1. Hi I had a problem with a avi file which I wanted to burn into vcd.
    Problem is this. I needed to extract the avi first to get a wave so that it can be sync with it later on to get a valid mpg format. When I wanted to open it with virtualdub to extract the wave file I got a message that says: cannot detect file type of "c:\abc.avi"
    I open g-spot to determine what exactly is the problem with the format. And it says:
    File type: Ogg Media
    mime type: application/x-ogg
    ... and nothing else. What does it mean by that? So is there anything I can do about it? Thanks.
    Dec 2004
    Australia
    Means that it is not an avi. It is an ogm with .avi for an extension. Try VirtualDubMod as it supports ogm.
