hey im just about to format my new hard drives(2x 160gb) for my new computer. Now here goes.. im going to be doing A LOT of video editing,capturing & using lots of programs.. what is the best way to format the drives? Do i put all my programs on one drive, capture off another drive? I'm not sure what is the best way. So i'll take advice from all of you. thanks
If these are the only two hard drives that you'll have in the PC, I would choose to partition one drive with about 20GB for OS, basic apps and paging file (C: drive). The rest of the drive I'd leave for your documents, downloads and major applications as well as your encoding source. The second hard drive I'd format as one big partition and use for encoding. I'd format all the partitions NTFS.
Nothing can stop me now, 'cause I don't care anymore. -
hi there.. thansk for your reply..i'll most likely add one more 160gb drive to the system as well.... what should i do now?
If you're going to use 3 drives I'd setup the first one the same as above and stripe the other two if you're mainly encoding to it and not saving anything critical on the array.
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 07:19 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
