I am in the process of evaluating dvd lab pro. Once I import the movies, mpeg and pcm sound file, I attempt to play the movie in the preview window there is no sound. The audio track is included on the movie one time line. Is there suppose to audio in the preview? What am I doing wrong? Thanks
http://www.mediachance.com/dvdlab/dvdlabfaq.html
Why no preview with audio?
The main reason are the Elementary streams (see above). DVD-lab can't preview together the elementary video and audio in its preview window. In fact this is almost impossible to do in realtime without a special syncing hardware or without some prior pre-compilation. Such attempt in software will most likely produce a false sync problem - something which is far worst than not hearing audio at all.
The job of the Preview window is to set chapters and to locate some video stills you can then use in menus. To hear audio for this task is not essential. You should insert chapter points to a video clues such as scene change. In fact since the chapter points in DVD are bound to video I-frames you won't be even able to add chapters with any big precission to audio clues anyway. -
Thanks for pointing me to the obvious place to find information about this tool
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 05:42 -
DVD Lab Pro 2: Demuxing errors & Chapter Inquiries
By evilpr in forum Authoring (DVD)Replies: 8Last Post: 22nd Jul 2008, 03:40 -
dvd lab pro 2
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 7th May 2008, 02:39 -
Help with DVD-lab pro
By Jack the Ripper in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 08:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
