I want to capture in SVCD format from vhs and then burn videos in CD-R, What are the best SVCD settings to capture from vhs.
In few words I want to say the best ratio video bitrate/quality...
...thanks!![]()
Read first "what is SVCD" on the left of this page.
Resolution should be 480X480 for NTSC and no more than 2700 for bitrate depending on the duration. You have to use the BitrateCalculator which can be found in videohelp.com for the exact calculation of bitrate depending on the duration of your footage and the sound bitrate (for me 192 is ok, mabe less is also ok). There is also a free program for this job (FitCD).
The rule is less footage----->higher bitrate----->better quality because a CD is only for 700Mb the most. If you wanna fit more time you have to compromise in lower bitrate=less qualityKONX OM PANX -
Note that many SVCD "certified" players choke on bitrates above 2000 kbps - as VHS captures are pretty "low res", you might be better off encoding to CVD (1/2 D1) - that way, it's also simple to reauthor as DVD, the day you get a DVD writer (remember - it's not if that's gonna happen - it's when, right?
/Mats -
Can I capture in CVD format (CVD 1/2 D1) with ATI AIW rage 128? How can I do?
I use Windows XP SP2, my cpu is Amd 750 MHz, hard disk 20GB 7200.
Thanks a lot!
Don't know nothing about ATI cards, unfortunately. What does you manual say?
/Mats -
A friend of mine is selling to me an AIW Rage 128 32MB AGP capture video card with tv tuner, I want to say if it's possible to capture in real time in CVD format using MMC ATI software.
thanks -
With your systems spec, I seriously doubt it. AFAIK, AIW cards don't do hardware (at least not 100%) mpeg encoding, so depend on your processor, which is on the lean side these days.
/Mats
VHS to S Video Capture Help
By bob52 in forum Capturing and VCRReplies: 11Last Post: 2nd Mar 2012, 01:17 -
Ulead VideoStudio 7 Capture VHS for PC / SVCD or DVD playback
By JonnyAlpha in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2010, 14:46 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 19:42 -
Entering Video Bitrate Makes Preset Switch To SVCD
By akulier in forum ffmpegX general discussionReplies: 7Last Post: 26th Feb 2008, 05:12 -
By akulier in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2008, 04:31
