First, sorry if this is in the wrong forum, I couldnt find one to match exactly
What do game companies use to capture there games?
I want to capture video games.
Money is not a problem.
I want to know what hardware I need.
Capture must be done with hardware on 2nd computer to ensure the game is running at max fps. on computer 1
Game will be played using latest card from ati or nvidia on computer 1 at minimum of 1600/1200
Computer 2 will be used to capture the video/sound - though I dont know what hardware to use, Ive searched over the net but cant find anything other than frame gabbers, software capturers, dv authorers etc
The new ATI cards have 2 DVI outputs,
Are there any capture cards with a DVI Input/s?
Is your target audience going to have the game installed? Not sure about recent games but Q2 used to have a movie feature but it would just record the movements of the players not an actual movie. You could then load it into the game for playback. The only drawback is you need the game installed.
There is a little app called FRAPS, which is specifically written for capturing OpenGL or DirectX games:
http://www.fraps.com/ -
As I see it, it's just a question of raw computer power. On the other hand, it would be cheaper for you to buy a decent standalone DVD-recorder and record straight into it.
photo capture from video signal hardware
By huegel in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 10:50 -
best capture hardware and best results for capturing video 8 and later VHS
By mayhampixi in forum Capturing and VCRReplies: 2Last Post: 4th Jun 2011, 22:51 -
VHS capture hardware (again)
By ccooper in forum Capturing and VCRReplies: 37Last Post: 25th Nov 2009, 14:25 -
Best hardware capture card for Beyond TV
By videoguy01 in forum Capturing and VCRReplies: 0Last Post: 22nd Feb 2009, 14:39 -
Advice on High Res Video Capture Hardware
By Gregus in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2007, 15:54
