Ok here is the deal. I capture some video using virtualdub. The captured video is good on my computer.
When I authored these AVI's to DVD, the playback on the TV is jittery. From what I read here, this is because I have the field order reversed.
I plan to encode these AVI clips to MPG and correct the field order at the same time. This is my problem:
The total lenght of the videos is 2hrs 13 minutes. I opened up TMPGEnc (to encode the AVI's), and I look at my options for audio, I am allowed PCM or MPG. PCM is too large to retain video quality and I've read on another site that MPG audio can possibly give compatiblity problems.
So I guess my question is, how can I correct the field order and still use AC3 audio? I plan to use Ulead DVD MovieFactory to author DVD.
Thanks,
Mako
Baldrick,
Thanks for the reply. Yes I do have DVD MovieFactory 3 Disc Creator Edition. I forgot to mention that in my orginal post. One last question... Is MPG audio and AC3 audio the same quality when encoded at the same bitrate? Just different formats?
Thanks,
Mako -
If you are making DVDs for your personal use you can probably use MPEG audio. All PAL players, and most NTSC players support it.
Originally Posted by 69mako"Art is making something out of nothing and selling it." - Frank Zappa
Audio options AC3 vs DTS
By jamesj84 in forum AudioReplies: 1Last Post: 7th Mar 2012, 20:25 -
Easy/Fast MPG to DVD Options?
By beckmen in forum Video ConversionReplies: 5Last Post: 25th Feb 2010, 17:41 -
2 mpg stills: same encode options, vast quality difference ??? (linux)
By jungle5150 in forum Video ConversionReplies: 7Last Post: 26th Jul 2009, 10:14 -
How to convert MPG with AC3 audio to FLV? --> HELP
By CineManno in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2008, 02:56 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48
