i have 2 problems:
when i play the mpeg file in WMP 7.1 that i converted from an avi file, the progress bar goes right to the end in about 5 seconds after playing the file, that means i can't fast forward it.
the file was converted to PAL with TMPGEnc 12a.
my second problem is that there's some green-purple line at the bottom of the screen.
thanx 4 your help
This might be a long shot, but if you happen to have installed WinDVD or LSX Suite, I suggest you try to Uninstall it and see if that fixes your problem, as I have heard of the green line with many people who have installed either one of those applications.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
i don't have any of the programs installed, but i found out that i only get that green line when i convert files to pal (doesn't matter anyway coz when i play them on my dvd player u can't c them), and for the media player progress bar, i don't have a clue.
I sugget you try using the Media Player proprties on your MPG file and see what are teh codecs being used to do the playback.
Best Regards,
Sefy Levy,
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
Is playback of mpeg-ps streams possible on a pc?
By craig198 in forum AudioReplies: 2Last Post: 26th Apr 2011, 12:12 -
Choppy playback after converting an MPEG...
By takearushfan in forum Video ConversionReplies: 23Last Post: 7th Oct 2010, 13:32 -
Still a Playback Problem with MPEG Video Wizard DVD
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 23rd Aug 2008, 04:02 -
Will the QT MPEG-2 Playback addon help my no MPEG audio on vegas problem?
By Nuke Shower in forum Video ConversionReplies: 5Last Post: 9th Apr 2008, 17:01
