ok when i try to back up some dvd's sometimes they dont work, when its finished and i take it out and play it on the dvd player for my TV it has like a problem that looks like what would be a VHS tracking problem ?? its not the burner/program/or media as other movies came out just fine, AND when i play it on my dvd player on my PC or XBOX its just fine. i am thinking possibly that im not doing somthing right for specific file formats... has anyone had this problem ?? and can help??? i use a NEC DL burner, and usually dvd shrink, but sometimes nero 6.0
Check the compatability of your blank DVD's to your DVD player (the one to your tv)...perhaps you should try using a different type of blank DVD. Just a thought...if you look through this site you should be able to find if your blank DVD's are compatable with your type of DVD player.
well if it's not the burner, program or media that would make it either the video itself or the player. However, typically when some DVD work and others don't, that would indicate a media issue...Originally Posted by APFable
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
Restore a DVD+R that wont play
By ProfHiggins in forum MediaReplies: 10Last Post: 14th Dec 2009, 23:49 -
JVC Wont Play New DVD's!
By Raxxor in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2008, 14:02 -
LG DVB-T wont play DVD's
By scdom in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2008, 08:20 -
*for all who use nero,and dvd wont play in your stand-alone*
By headstate in forum Authoring (DVD)Replies: 182Last Post: 24th Jul 2007, 03:00
