Well, i am learning a lot from the replys. Tkz a lot ppl.
As i said before, i did my best.
Cheers!
Simps
Results 31 to 43 of 43
Originally Posted by simpsWant my help? Ask here! (not via PM!)
Mine are all my own before I started using a DVD writer (read 'afford'.......people forget just how much they used to cost (£500 only 3 years back..and then the media) to make back ups...I never understood VCD or SVCD back-ups..why use two or three CD's when one xvid gives better results?)..played through TV-out..and later through an avi enabled DVD player..and even later, now that DVD players are so cheap (circa £30), I convert back to DVD (a player in everyroom).
So whats your post trying to say....where all pirates?
And the TEST is wrong anyway...it proves ZERO...as anyone who 'plays' with x/d's will know. -
Originally Posted by monzieWant my help? Ask here! (not via PM!)
Interesting test. It would be much better to use a source that has not been encoded to mpeg4 first.
As for CCE 9 pass, I find using that many passes can actually make the image look worse. -
I read this topic serveral times to get a better grip of things,
after the over-loading fiuse's I had to jump over. Anyways.
I think that if I understood correctly, that the test, though
based on and Xvid/divX format, that the results finality/conclusions
are for just that. Based on Xvid/divX format only.., and only that
format.
If you were to start throwing in other format, then the test would
become tainted w/ confusion, hence null-n-void, IMO.
When we are performing important tests, our medium should always
be of highest quality, for maximum and believable results. The reason
why I'm driving in this direction, is because we are evolving into higher
and higher quality source mediums. As these mediums get higher quality
(over time) so should our "tools" of testing. That means the source.
DV (I'm a lover of) is pretty much here to stay, and it serves as
a great test medium. Specially with clean source materials to begin
with.
One of the reason why I mostly stay away from other formats (ie, Xvid
divX etc) is because with these formats, (of which I worked with many
times over) always looses out in the end. There are too many variables
to adjust to make it consistant or standard of a gauge to use as a
test medium. In other words, if you use 1.2.3.4.5 in your tests, you
should not be altering them, such as, 2.4.3.1.5 for instance. And to
me, that's what Xvid/divX (mpeg-4) does to me. Its just too unreliable
to use as a test tool.
I would prefer, as I stated above, DV, or else even MPEG-2 (using
standards of course, and they are much easier to set and be consistant
with, then say MPEG-4 is - is not)
-vhelp 3069 -
Encoder does not "know" what source material it is reencoding therefore every test is as legitimate as other. In either case frames are decompressed be4 reencoding so eventual degradation may be a cumulative of encoder plus decompressor's quality. Both are relevant and good to know in terms of expectations. I think testing, as in this example, was in that respect absolutely no less useful then from the original uncompressed source. Every encoder has its weak sides and test like this may shed some light onto them. I'd be also curious how they do in high bit areas (examples here are from rather static, low motion clips).
I believe that Main Concept MPEG Encoder is the best for batch encoding jobs.
It's the only tool I've used that performs everything I've asked of it. I wanted something that would effortlessly burn avi's (in any codec) to mpeg1 or vcd. It'll also auto split the files to fit on a cdr.
While the quality isn't the best (barely less then the competition), nothing compares in speed and ease of use in batch jobs. If I have 5 avi's, it takes less then 5 minutes to set them all up to be done. I average about 30-40 minutes per movie on a p4c 3.4gig. -
it might be easier to tell the overall comparison of an original dvd vs. the one that came from a xvid/divx by including some frames of the original source (dvd)..
not sure if this is what you were trying to compare.. but for me it would help to see what type of quality you will be getting compared to a direct copy of the mpeg-2 dvd... -
I thought this was some great info. I'm still a little new to this whole thing and have been wondering if the quality of the different encoders really justifies the cost. I'm picky about quality... but i'm also picky about not going bankrupt. I've made some svcd's from DIVX sources (Halo 2 fan montages... nothing illegal...) so this really helped. Thanks again...
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
about mpeg-2 encoders
By sgbd in forum Video ConversionReplies: 6Last Post: 11th Sep 2010, 07:02 -
Hardware MPEG 4 Encoders: Worthwhile?
By darkarn in forum Capturing and VCRReplies: 6Last Post: 29th Jul 2010, 19:16 -
A Test of 3 Encoders (and Confusion about Aspect Ratios)
By 201flyer in forum DVD RippingReplies: 3Last Post: 2nd Jan 2010, 07:25
