ok guys..im not so good with those softwares, so if you can plz recommend for me the best software to burn a dvd to my computer, like to make another copy of that dvd
Dvdshrink and dvd decrypter.
ok, after all the files are added to a folder, i just burn wats in the folder and it will play like a regular dvd?
If original DVD is larger then 4.7 gig than you need to run dvd shrink on it to go from dual layer down to single layer size I recomend using automatic compression till you get used to it. If you have nero installed then checking the auto burn option in dvd shrink will burn it when done re encoding it.
Also if your orignal is in decent shape you may want to uncheck the deep scan option in dvd shrink this will save you about an hour of time in the process. hope this helps. Gforce598 -
after dvd shrink and i have the files on the computer, i just burn all the files in the folder it was put in and it will play like a reg dvd?
If the source DVD is<4.3 GB - DVDDecrypter ISO read/ISO Write.
If source >4.3 GB - DVDShrink to ISO, DVDDecrypter ISO write.
/Mats
Is there any software recommend to handle TS in the following way?
By ihmcjacky in forum Video ConversionReplies: 11Last Post: 2nd Dec 2010, 14:29 -
can you recommend good ripping software ?
By Bansaw in forum DVD RippingReplies: 2Last Post: 14th Sep 2010, 19:39 -
Recommend a software for M2TS
By vid2me in forum Video ConversionReplies: 4Last Post: 26th Aug 2010, 16:30 -
Can anyone recommend a freeware screenwriting software?
By rijir2001 in forum Off topicReplies: 0Last Post: 26th Nov 2009, 00:44 -
Please recommend software
By ccm2 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2008, 12:23
