  1. How do I back up the hard drive to DVD-R? I thought I saw someplace in Nero to do it, but I can't find it now.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Nero has it's own software called BackItUp, which can do this for you.
    If in doubt, Google it.
  3. I only had that in a 30 day trial, it's gone now. Is there some other way?
  4. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    I use Norton Ghost. Anyway you go your going to need to purchase some kind of software for Backup purposes.
    Nov 2003
    Moreno Valley, Ca
    use Barts Pebuilder to create a bootable xp enviroment cd and add the nero plug-in.
    Other plug-ins can provide access to adaware and anti-virus free software
    When booted with this cd you can then burn any or all of the hdd to cd or dvd.
    assuming you have a free copy of nero from a purchased burner then it is all free.
    three folders to copy to restore system:
    1. Documents and Settings
    2. Program files
    3. Windows
    This is not the same as writing an image file or compressed backup type file. Just a uncompressed data copy.
    There was a post some time back giving step by step method of backup via a dual boot xp system, this is basically the same without the need to have a dual boot system.
  6. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Pay for it?
    (Is this a trick question?)
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
