  1. Hi all,
    I'm new to this group. I'm running into a problem with the VCDs I burned with Nero. I simply followed the "How to author VCD" instruction on this site and burned a few VCDs with my Nero demo software. None of them can't be play in my Toshiba 2200 DVD player. The tv screen stays blank with a line of text saying: "check disc". Can anyone please help me out?
    Thanks.
    Shaun
    _________________
    http://www.shaunau.com
    <font size=-1>[ This Message was edited by: shaun_au on 2001-12-05 23:40:48 ]</font>
  2. Check if your DVD player lets you play CD-R media.If it does then send me your email address & i will send u a file to help you.
  3. Member Dhruv's Avatar
    Aug 2001
    Australia
    Does it work on your computer?
  4. my dvd-player (panasonic 350a)also don't play cd-r (vcd), but only cd-rw (vcd). try it. i burn always with nero.
  5. Your player doesn't do well with CD-R's at all. See the following from this site's DVD Player compatibility list:
    http://www.vcdhelp.com/dvdlist/488.html
    CD-RW's should work OK.
  6. pats i have the same problem with my car dvd player it plays dvd,vcd,cdr.original vcd work great but i cant get any of my burnt ones to play.they work on my home player.any type cd/r cd/rw silver,gold,blue,green all no luck is there some difference between original and burnt other then original being pressed."regional code" or something?thanks
  7. The VCD works on my computer. I used PowereDVD player on my Windows 2000 Server to play the disc. The movie ran flawlessly. My Toshiba SD-2200 plays other VCDs I got from Hongkong just fine.
    I guess I need to use CD-RW then. Also, I need to upgrade my Nero demo to the full version. Hope those two would help.
