I've got an mpeg2 encoder card, and I'm trying to convert some of my recorded tv shows (regular 4:3 format) to xvid. The resolution of the captures is 720X576, and I was using AutoGK to convert to xvid. For the audio I was using Lame 128K mp3.
All my conversions are ending up close to 500 megs, even though the shows are only 20 minutes long after the commercials are edited out! I'm guessing the files should only be about 175 megs (from other conversions I have seen online).
What could I be doing wrong? I thought I might need to resize, but I didn't see any options to do that. Do I need to use other software with more advanced options (like virtual dub)?
Any help is appreciated. Thanks!
Originally Posted by Baldrick
Size = bitrate*time. The resolution would effect the bitrate if you were encoding at a fixed quant though.
640x480 at Q2 should be smaller than 720x576 at Q2.
XVID conversions too small
By coyote2 in forum Video ConversionReplies: 117Last Post: 16th Nov 2011, 15:48 -
WMV to Avi(xvid,mp3) using VirtualDub - huge destination file
By chm in forum Newbie / General discussionsReplies: 9Last Post: 20th May 2010, 17:29 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 4th Mar 2010, 23:50 -
GOP length and filesizes (HCenc)
By Movie-Maker in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2008, 10:41 -
How does it work from .avi to DVD with filesizes
By herbster in forum Authoring (DVD)Replies: 6Last Post: 10th Dec 2007, 19:17
