OK Me and my buddy had a great brain fart... get a converter and go from bnc out on my Viewsonic 19" outs and run to RGB composite in on my HDTV..... can and will this work....?
thanks
thanks Z..... I really have no idea about this and I would really just leave all this cr@p on my computer then try to go through the hassle of converting adn burning and all that..... I think this is a much better approach...
only $100. for the converter and I can make all the cables....
so why bother with all the rest....
why would you run it composite anyhow?
Comsposite is only some 300+ lines of resolution if I remember correctly. S-video might be a better approach.... -
I didn't know the specs.....ahhh I had hoped it would be better resolution....
I couldn't get super video to work off my asus 7700 out to work..... not sure why....
I guess my trek is not so easily solved.....
anymore suggestions.... just about to buy new philips burner progressive scan.... Im also hopin I can try svcd or vcd there......
Using my HDTV as a monitor for gaming
By Darco32 in forum DVB / IPTVReplies: 2Last Post: 31st Jul 2011, 05:37 -
HDTV-Bad Signal?
By crowheart in forum DVB / IPTVReplies: 11Last Post: 29th Oct 2010, 02:31 -
Direct TV/HDTV Signal Question
By RKelly in forum DVB / IPTVReplies: 5Last Post: 12th Mar 2010, 01:55 -
Does CW do something to their HDTV signal?
By mattman1968 in forum DVB / IPTVReplies: 3Last Post: 9th Jun 2008, 09:21 -
Looking for a device to output signal as second (or mirrored) monitor to TV
By ViRaL1 in forum Off topicReplies: 0Last Post: 29th Aug 2007, 12:33
