i just wanna ask your personal opinion how to use dvd shrink
i open dvd shrink
i open my dvd
i uncheck the languages i don't need also the extras if i don't want them
then i push on backup ,select a folder on my hardrive ,
i let encode
and then i load them into nero express and burn them
do you think it's a good way or did i forget something
thx
Results 1 to 10 of 10
Hello,
after opening the dvd I use Re-author. In the re-author dialog you can drag the main title to the left and select the audio and subtitle. Then I use backup. This way only the movie with the selected audio and/or subtitle is written to the backup medium. No menus, no extras.
Regards,Geert
Smalfilm- en Videoclub Lumiere
Eindhoven -
Many guides for dvd shrink. Look here;
http://www.dvdshrink.org/how.html -
Okay i do everything you do in shrink.Originally Posted by gringos
I depart from your method after that.
I use Nero to create an ISO image file with the files.
I then use Decrypter to burn to disc.
I am very much ONE TOOL <---> ONE JOB
But the whole thing is do whatever works....
Do you have any problems with your method? If not there is now real need to change.
Upto you.... -
Why use Nero to create an ISO when DVD Shrink can do that?
He's a liar and a murderer, and I say that with all due respect. -
Very much becauseOriginally Posted by steveryan
DVD Shrink ------ SHRINKS thingsOriginally Posted by zworg2
:P :P -
No Need to use Nero to create ISO, shink does that for you. Just another program and another step. Just use Decrypter to burn ISO.
Imagination is More Important Than Knowledge -
I use DVD Decrypter to rip the DVD to my HD without any compression, this way I can watch the DVD in it's original format from my computer which is connected to my TV. If I back it up to DVD, I either use DVD shrink to compress the DVD or I plan to begin buying dual layer discs so that I can bypass having to use compression at all.
I think your current system is sound though, use dvd shrink to rip to your HD, use Nero to burn to DVD. -
I have had problems when i use shrink to make ISO.Originally Posted by Severity
The autorun doesnt. Decrypter doesnt like the iso..alll sort of odd little things.
so i ahve stuck to using Shrink --> Nero ---> decrypter
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
