  1. I know how to use Cover XP Pro to make a cover for a single DVD case but how do I stretch it to fit a 6 disc DVD case? The front and back portion of the case is the same but the middle is just a little wider.
    Does anyone know which template will work or do you know what the custom measurements would be?
    Jun 2014
    Amsterdam
    I don't know how to enter a new thread so I will probably be doing something wrong right now, for which I apologise.
    Concerning making labels for my dvd's, I just read that this is not a very good thing to do, because the dvd will be ruined within a short period of time due to the chemicals in the glue.
    I have never experienced a problem myself, but would like to know more about the possible risks.
    Can the label also bring the dvd out of ballance due to a poor centric position of the disk?
    By the way, I still have not solved the problem, finding the right template for coverxp pro.
    Thanks for any help and greetings from a sunny Amsterdam, Peter
  3. The OP guy didn't get much help the first time; you might have been better off to start your own thread! I haven't used Cover XP, but it sounds like you're using the wrong template for that label. Most of the programs I've used would let me choose a template from a label catalog; I remember seeing labels from CD Stomper, Avery Denison... Find the label that matches the code on your label package. If Cover XP doesn't have a catalog it should at least let you tweak the positioning of the different print items, look for an edit or modify button while in the template selection menu.
  4. Member Backpain's Avatar
    Oct 2009
    Try using UndercoverXP. It has an option for 6 disc print in the drop down menu.
    If it feels good, do it.
    Jun 2014
    Amsterdam
    Does undercoverxp work with the same code, or do I have to buy it again?
    Thanks, Peter
  6. itīs free software
  7. Member Backpain's Avatar
    Oct 2009
    It is a free program. Go to http://www.undercoverxp.tk and download it. You can donate if you like the program.
