hi...
i need help on how to connect my vcr player to my computer so that i can record the tape into vcd...
i don't wat type of wire to use and whether to put it in the video input or output.
pls reply asap!!!
thanx alot!
You Must Be New to THE WHOLE WORLD of audio Video. It's Easy! All you have to do to connect the cables is run a Video cable (yellow) from the "OUT" on your VCR to the "IN" on your capture card and do the same for the audio. Make sure that you match colors on the cables and the equipment (e.g. yellow to yellow, red to red, white to white)
Good Luck! -
i am sure you have this info...but if not here are some links:
http://support.ati.com/connectors/radeon_aiw/connect_radeon_aiw_video_output.html
http://support.ati.com/connectors/common/connect_tvout_audio.html
http://support.ati.com/connectors/radeon_aiw/connect_radeon_aiw_video_input.html
Need a program to capture VCR through Hauppagge card
By granturissimus in forum Capturing and VCRReplies: 7Last Post: 1st Feb 2011, 15:56 -
How do i connect audio on capture card?
By GLE3 in forum AudioReplies: 11Last Post: 9th Mar 2009, 22:06 -
Connect VCR/DVD Recorder to PC which has TV Tuner
By Butch1942 in forum Media Center PC / MediaCentersReplies: 1Last Post: 16th Feb 2009, 19:03 -
Dazzle dvd recorder capture card and a VCR problem
By leeh in forum Capturing and VCRReplies: 5Last Post: 3rd Jul 2008, 13:53 -
How to Connect VCR to ATI 650
By jshapard in forum Capturing and VCRReplies: 0Last Post: 22nd Sep 2007, 11:18
