I'm prepping a new public web server. This a.m. I copied over 12 gigs of data from one "wwwroot" to the other.
Now, are there any tools I can run that will compare my two shares and show me any 'delta' files located on one share not found on the other?
TIA
I love FileSync
http://www.fileware.com/products.htmBig Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress? -
WinMerge will do it. It'll also tell you if there are any differences in the files themselves.
http://winmerge.org/
The hard part will be if you're trying to do it from a remote machine. If that's the case, you'll probably have to VPN in and map network drives.
If you have physical access to one of the two servers (or a computer on their network) it'll be easier... in that case you could just browse the network for the directories to share in WinMerge. -
Thanks .... I have two drives mapped to the wwwroot share on each.... will try these apps out.
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 14:17 -
H.264 Converter Comparison
By Joynr in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 01:11 -
comparison between bluray and brrip
By xenotox in forum Blu-ray RippingReplies: 13Last Post: 24th May 2009, 15:17 -
CL (in Ram) comparison
By Seeker47 in forum ComputerReplies: 3Last Post: 20th Jan 2009, 15:01 -
Comparison Chart of Over 40 HD Cameras
By Gary Roberts in forum DVB / IPTVReplies: 0Last Post: 17th Dec 2008, 09:32
