I have the Aerocool Gatewatch fan controller temp monitor, The problem is the only fan I am able to hook up to it is the CPU fan. My case fan has a regulor power connector like that on a IDE device, and I have the ATI AIW 9600XT video card, the fan on it has only a small 2 prong connection.
My question is:
Does anyone make an adaptor that I can use to connect these fans to the Aerocool Gatewatch wich has the same connectors like if you were connecting the fan to the MB.
When I bought a new case fan in Nov. it came with such an adapter. I'd check newegg.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
I'm just going to buy a new fan, the other one came with the case anyway.
Are the headers on that fan controller 3-pin? You need a speed-sensing fan for that if you want the controller to alter/monitor speed on those. If the fan only has a 2-wire tail you probably don't want to mess with using it on a fan controller. Also check to see if your controller can handle 120mm fans if you're using them. Some controllers don't like the low RPMs those fans run at.
FB-DIMM are the real cause of global warming -
It has 4 headers all 3 pin and 4 temp sensors, (which is basicaly the end of a wire that you "tape" were you wan to sense the temp) that coralate to the fan. And I'm pretty sure it will work for 120mm fans (I don't have one anyway, yet) I believe the min RPM is 800 or 900.
Make sure to get 3-pin fans then. I recommend getting fans from either
www.sidewindercomputers.com
or
www.frozencpu.com
I've purchased plenty from both. If you need some recommendations just ask, just be sure to let me know how the fan will be used. There are different applications for different fans.FB-DIMM are the real cause of global warming -
I already bought one from newegg, this one:
http://www.newegg.com/app/ViewProductDesc.asp?description=11-999-906&depa=0
I hope it works if not I'm only out 6 bucks
Case fan not spinning
By beavereater in forum ComputerReplies: 18Last Post: 15th Sep 2011, 14:51 -
AC to USB Power Adaptor
By Frank-0-Video in forum ComputerReplies: 2Last Post: 4th May 2011, 09:49 -
power adaptor
By n0p3 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2009, 21:21 -
what adaptor for protable hardrive should i use.
By krnjason in forum ComputerReplies: 7Last Post: 28th Nov 2008, 07:45 -
AC adaptor for PANASONIC PV-GS39
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 2nd Sep 2007, 14:59
