Hi
I’m up to converting DVD to VCD.
In the commercials VCD that available for buying the quality is the best possible. when converting from DVD I cant rich that quality.
The most noticeable quality decrease is presented by the big cubes/pixels that appears on my converted VCD on the TV screen .obviously its due to the resolution that VCD specification requires. I was thinking that its because I’m using a commercial DVD as a scours so the target must be effected by that but I’m still confuse….if the DVD frame size is 720x480 and the target frame size is 352x288 ….the quality should remain because the original is much bigger than the target…so why the quality seems to be low and how can I avoid those noticeable cubes that The commercial VCD doesn’t have it.
S
NTSC to PAL?Originally Posted by samifox"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Which programs are you using? Did you try the NTSC VCD template in TMPGEnc? Are you encoding a compliant VCD....blocks usually means bitrate too low. VCD is 1150 CBR.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Hi im using VCD PAL template inTMPGEnc.in the scoure clip i change the input the 4:3 PAL and for the output i set it as well 4:3.
the movies sometimes is 16:9 but i want to be on a full screehn....it might be the reason to cubes?
and the bitrate is standart.
Thanks -
Why? Your source DVD is NTSC.Originally Posted by samifox"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
yeh ! i make PAL (x) vcd, bitrates as low as 700 (of course its in cinema scope!!), but the quality should rival a original VHS at least !!!!
i use tmpeg, the reasons for the blocks is your motion search is set to normal , set it to high quality at least !!!!!! try a vit of the source let us know.....
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
DVD to MPEG2 convertion
By Divider in forum Newbie / General discussionsReplies: 5Last Post: 8th Mar 2009, 05:12 -
Convertion problems
By M_2008 in forum ffmpegX general discussionReplies: 2Last Post: 4th Jul 2008, 16:49 -
mp4 convertion
By ht0160 in forum Video ConversionReplies: 2Last Post: 15th Feb 2008, 02:09 -
Video convertion
By kireetkvn in forum Newbie / General discussionsReplies: 3Last Post: 10th Sep 2007, 01:50
