hi,
what is the best codec to use for doing vj footage : what i mean is, good resolution (640x480), good quality, i don't care about file size, but i do care about CPU. i'm using ffmpeg to encode from a dv/29.97fps/720x480/avi to if possible a libquicktime file or avi. i tried xvid (with keyframe every frame (gop 1)) but it eats a lot of cpu when decoding the file.
any recommandation would be appreciate!
pat
[/b]
Results 1 to 1 of 1
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 14:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 20:26
