Here are the specs on the .mov am trying to convert to avi-
640x480
15 FPS
7.6kb/s AUDIO
428.8KB / Sec Video
I have tried EO video converter, but when I try the files back in Quick time player they stutter.
Same problem Tmpenc Express.
The question is, I want to keep the EXACT same quality in the conversion and think .avi is the way to go, but don't know what to set the output settings to. The final goal is a dvd disc.
Do I output to 30 fps .avi ? What about other audio,video settings?
any advice appreciated.
-zep
quicktime is crap for playing mpeg - even if you get their mepg plug in (which you would have to) ...
tmpgenc , main concept or procoder will resize your material and double the frames for ntsc ..
just pick one and use it .....
the end quality not going to be great - but usable ..
you might want to not resize it up - but just add borders ... will look better a bit - though aspect ratio will be off a little ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22 -
Advice please for a newbie - AVI to different format with subtitles
By brodders20 in forum Newbie / General discussionsReplies: 5Last Post: 21st Jul 2009, 16:10 -
.avi to .mov conversion nightmare
By towarmforacoat in forum Video ConversionReplies: 4Last Post: 20th May 2009, 16:16 -
Converting a mov format to avi in Vegas 6.0
By solarblast in forum Newbie / General discussionsReplies: 10Last Post: 25th Sep 2007, 11:29 -
AVI to .Mov conversion
By HD_Shooter in forum MacReplies: 10Last Post: 18th May 2007, 08:45
