I can't seem to get rid of the top and bottom borders when I convert from avi to svcd with DVD2SVCD no matter what aspect ratio I use and even changing the setings on the DVD player won't remove them.
My movie that I am converting has a resolution of 720 x 304 and I am resizing to "SVCD 480x480/576" in the "Framesaver" section.
If I set the "Resize to" setting to "DVD 720x480\576" and preview the video before converting by pressing "preview video (still picture)", the borders disapear. Will this setting, (DVD 720x480\576) remove the borders and still give me good picture quality or is there another setting that I have to change to get rid of the borders?
Thanks.
Results 1 to 13 of 13
I don't know much about the workings of DVD2SVCD, but you could always resize the video outside of that tool, using for example, virtualdub. The problem thne will be that you will lose the original Display Aspect Ratio. SVCD does not support 16:9 DAR, so it will always encode as 4:3. In order to maintain the DAR of the original, the black borders are added. If you don't do this, everthing will look squashed horizonatlly and people will look tall and skinny. Is that what you want?
There are 10 kinds of people in this world. Those that understand binary... -
Originally Posted by peter p
2) Widescreen is 16:9 or 1.76:1, your avi is 2.36:1, so if you remove the black borders and stretch it to fit a 16:9 screen, the AR will be screwed up.There are 10 kinds of people in this world. Those that understand binary... -
I converted another movie and for some reason I had a border around the left and right side. I then changed the avisynth script file to "^b= 0.33
and ^c= 0.33" something like that. I read LeeBear's article on how to do it and that removed the left and right borders but had no borders at the top. The movie fit my whole TV screen
The second movie I converted has borders at the top and bottom with the same settings.
My TV is a widescreen and I can change the settings from wide screen to letterbox to PS??? but that still doesn't remove the borders. On a original DVD movie, changing the widescreen setting removes the borders.
I don't know why one movie has borders with the settings and the other one dosen't. -
If you have a 4:3 TV and play a wide screen movie you have the choice of letterboxing, so it displays with black borders top and bottom, or filling the screen which the player does by zooming in on the middle of the picture, chopping off the sides. Even when you do this some movies shot in aspect ratios wider than 16:9 still leave (smallish) borders top and bottom.There are 10 kinds of people in this world. Those that understand binary... -
Originally Posted by peter pThere are 10 kinds of people in this world. Those that understand binary...
what i do in cases like this is get a piece of paper, and write down the original frame size (720 x 304)
i like to work in pal as i'm in pal country. and avi is usually in 1:1 par and dar. So i convert the above frame size to see what it would be in a 768 x 576 container.
720 x 304 (1:1) (1:1)
=768 x 324 (1:1) (but in 768 x 576 frame size)
= 720 x 324 (4:3 in 720 x 576 dvd compliant frame size.
= 480 x 324 (4:3 in svcd frame size)
(576 - 324)/2 = 126 hence, you need to add 126 pixels to top and bottom, to keep the same aspect ratio of the original.
you will see this, by doing resize filter in virtual dub, to 480 x 324, and then expand frame and letterbox image to 480 x 576.
on the output pane, you right click and select 4:3 display ratio. YOu will see, that both panes have the same proportions now.Some people are only alive because it may be illegal to kill them -
Ok, I got it. My version was older and for some reason the output preview pane didn't show properly.
please post converting the converting forum. moving you.
How to get rid of black letterbox borders on AVI file?
By mukluk909 in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2010, 15:18 -
Black borders all around video
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2010, 17:01 -
Does anybody know how to convert 16:9 to 4:3 with black borders?
By tuanvn.2007 in forum Video ConversionReplies: 7Last Post: 20th Sep 2008, 02:13 -
how do you get rid of black borders when trying to convert file to DVD
By whodini in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 16:15 -
getting rid of black borders from ripped widescreen movies?
By curt1sw in forum Video ConversionReplies: 12Last Post: 20th Oct 2007, 04:35
