Hi,
OK, i'm still fairly new to all this but will try and explain my problem. I'm using DVD Lab Pro and basically I have 1 main menu with links to 8 sub menus. In each of the sub menus i have links to 2 movies. The idea is that someone can click on either button then watch that movie (which works fine) then at the end of the movie it returns back to the sub menu (which works fine). All this is setup in the connections window. Red line into the movie and a black line back out to the menu.
These movies are only between 4 & 30 minutes long. My problem is that if someone clicks the next scene button on the remote it doesn't exit back to the sub menu, instead it will start another movie. Is there a way to tell the movie to return? I thought that simply dragging the black line back to the menu in the connections window would do this.
Like I said if I just leave the movie to play it will return to the menu but not if I press next scene.
I hope you can help.
Cheers,
Stitch.
Next Scene is doing exactly what it's supposed to do, go to the next scene (the way you have it linked).
If you want it to return to the sub menu all the time, remove your scene links.
Post a screen shot of your connections tab, and someone will sort it out for you.Cheers, Jim
My DVDLab Guides
EVODEMUX Write Chapter Button?
By wulf109 in forum Blu-ray RippingReplies: 7Last Post: 13th Nov 2011, 12:26 -
'Play All' button in DVDauthorGUI works except for '>>|' (next chapter).
By dphirschler in forum Authoring (DVD)Replies: 14Last Post: 14th Jun 2011, 13:49 -
TMPGEnc AW4 Chapter Head Skip button NOT working
By BobAchgill in forum Authoring (DVD)Replies: 0Last Post: 23rd Jun 2010, 10:14 -
Fixing Chapter Selection Button (Link)
By sbernstecker in forum EditingReplies: 0Last Post: 14th Jul 2008, 14:27 -
Chapter button pop-up text description in GFD?
By awesomer in forum Authoring (DVD)Replies: 6Last Post: 18th Nov 2007, 20:21
