I've been using dvdshrink most of time.
I'm wondering does anyone know how to put the Audio languages in different order? I want to choose other languages (like DTS or 5.1) to be on 1st list of audios.
Just be careful doing this. The DVD Spec says that DTS should not be the first audio track. Some players may not be happy. The first audio track of the main title should be the same format as the audio on the menu. If it is not, you may not get the audio played on the main title. None of this matters if you are changing a single title only backup..
Read my blog here.
When ripping you should be able to remap any audio stream to 0X80, which AFAIK is the default audio stream (you can defintiely do it with smartripper). You may have to remap the existing 0X80 stream to whatever the DTS stream was though.
If in doubt, Google it.
is there a DV editor that can import all clips and put them in order?
By Onceler2 in forum EditingReplies: 0Last Post: 15th Oct 2010, 21:38 -
How do you change the order of audio tracks?
By FallenAngelII in forum DVD RippingReplies: 0Last Post: 29th Mar 2010, 05:22 -
Multiple AVI is WINAVI being put on DVD in the wrong order
By richco in forum Authoring (DVD)Replies: 7Last Post: 23rd Nov 2009, 06:50 -
Changing the Order of audio on a DVD
By PBoy in forum EditingReplies: 5Last Post: 15th Aug 2008, 00:02 -
the order of audio tracts is reversed
By volam in forum Authoring (DVD)Replies: 0Last Post: 16th Apr 2008, 20:37
