  1. My digital cable box only has composite video connection in addition to the coaxial connection. Will the digital cable channels look better or just as good on a EDTV as they would on a regular TV?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    mostly likely worse ... really ...
    Probably worse.
  4. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    is there anything coming out that pipe?
    I've seen many cable boxes that have such a connector but nothing comes outta there...
    For example, why wouldn't they send this to your set..... instead of the CHANNEL 3 or 4 RF signal that non-digital cable systems use, here in the UNITED STATES..
    its probaly not functional on your unit
  5. My cable box has a functional composite output (and separate left/right audio outs as well) but like others have said -- if anything, it's worse than the channel 3 RF signal. I thought at first I'd get stereo from the higher digital channels using the separate audio outs, but no dice. Comcast sux.
