How fast do you guys encode with DVD shink? I have a 16x DVD rom drive for ripping, and it only goes at around 3500kb/sec. I have a top end machine so I don't think that is the bottle neck. Is there something I can do to make it faster? I'm not talking about the analyzing phase here, im talking strictly the encoding phase. What are you all getting for speeds? How can I up mine?
I'm not quite clear what you are asking. If the ripping speed (reading the files from the DVD) is running at that pace, I would suggest looking for a firmware upgrade for your DVD Rom drive to remove the riplock. Also make sure the DV Rom is operating in DMA mode, not PIO.
Read my blog here.
3500kb/sec is not bad at all if you are actually compressing. If you use AEC it will vary also. I've got a fast system and if you use max smoothness, for example, it can dip below 1000kb/sec.
Lots of factors...ripping from DVD-R, DVD Pressed discs, amount of compression used if any, using AEC as Steve mentioned...
My 708A 12X can rip @ 11,500kbs(end of disc) using DVD5 (no compression) or 1200kbs (steady) w/ DL pressed DVD9 @ 60% compression AEC-default. Big difference. -
Strangely enough, I have found that is I rip from my external Sony 530ul fire wire I get much faster rip speeds than from my IDE drivean NEC 3500 DL 16x RW drive. I just set up DVDshrink to rip from the external to ISO and burn with DVD decrypter on the NEC. I Do not get astronomical speeds but I get about 5000-8000 kbs which I could never get off the NECHow fast do you guys encode with DVD shink? I have a 16x DVD rom drive for ripping, and it only goes at around 3500kb/sec.No DVD can withstand the power of DVDShrink along with AnyDVD!
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 06:45 -
Errors on Shrink ripping latest hit dvd's
By bluzjamer in forum Authoring (DVD)Replies: 9Last Post: 6th Dec 2010, 01:13 -
DVD Fab v/s AnyDVD Ripping Speed
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 25th Mar 2010, 14:04 -
How to shrink the file size of 7.63GB after ripping the DVD?
By coy228 in forum MacReplies: 6Last Post: 16th Jun 2009, 10:19 -
DVD shrink is only encoding @ 2500 KB/s or so? Instead of the 12000KB/s?
By Denvers Dawgs in forum DVD RippingReplies: 6Last Post: 29th Jun 2008, 11:23
