Price really doesnt matter to me as I want quality burns on my DVD backups that are going to last and not get jittery the first couple times I play them back.
I'm assuming right now that Taiyo Yuden is the best but I'd like to hear from a few of u that are still using this DVD burner what ur opinions are![]()
Thanks in advance
Results 1 to 13 of 13
as long as you stick to the RECOMMENDED BRANDS of DVD MEDIA that PLEXTOR supports then you will do fine. i have used with success DVD-R FUJI (TAIYO YUDEN) 4x speed & MAXELL 4x speed media which burns flawlessly on my PLEXTOR 708a drive. Both of those brands with the "MADE IN JAPAN" on the label are the one's to purchase. i have also used IMATION 4x speed DVD+R (RICOH) which can be burned @ 8x the speed. i have used RITEK G04 which is on PLEXTOR's compatibility list but the quality of RITEK has gone downhill so I don't use them anymore.
prices for media are getting cheap since the newer 16x drives are on the market. i have never used prodisc on my 708a drive but used them in my pioneer 107d drive which works fine.
the 708a drive can now support bitsetting for DVD+R media as long as you use firmware 1.08, plextools from version 2.17 or later and nero version 6.3.1.25 or later. hope this helps you out.
what i find amazing is the buffer level in nero is steady at 92 when i burn with my 708a drive. with my other drives the buffer level fluctuates between 85-95 or so. in my experience with the 708a the burn quality is excellent. i also had a problem with a disc not being able to be read by any of my dvdroms or other dvdrw's but the 708a was able to read the disc perfectly. there was a scratch towards the end of the disc which prevented me from ripping the disc. gotta love the plextor 708a
Recommended media is a good start.
As a side note, Plextor chose Taiyo Yuden to sell under their own brand name discs.
RICOH (maxell 4x +R made in taiwan)
Any Maxell (made in Japan)
Verbatim (MCC) - 8x -R media (I have heard good reports of this, at least with the 712A anyways).Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Alright I pretty much figured I would go with the Taiyo just wanted to be sure.
rima.com seems to have pretty good price of $68 on 100pks of these which seems good to me for 8x discs.
My only other question is that they have it in +R and -R for the same price.
Is one or the other preferrable? Or does it really not matter?
thanks so much for all the help guys! -
i like -r becuase it had an honest birth. +r was a result of greed and it really screwed up a lot of things.
But either one works the same, compatibility isnt really an issue -
What we are using fleeps, is written on the left column, under writers & some under media.
The DVD Media page has it covered. Better, Covered Up if you do not have search skills.
Whithout buying online, I am unable to find any Made In Japan media. I keep looking through the sales Media at Best Buy, Circuit City and CompUsa.
+R's burned in the 708A will not play in the house Panasonic DVD/VHS player.
-R Media that has worked well in the 708A:- Memorex ProdiscF01 (is that F oh 1 or F zero 1?) 8X
- RITEK G04
- TDK TTG01 4X
- TDK (Circuit City white printable)TTG02 8X
i understand on how to use the columns on the side you use them and u get 5 billion comments that range from positive to negative for all the same things and are very poorly organized and listed per DVD burner.Originally Posted by handyguy
So after spending 2hrs trying to sift through the nonsense and picking through my decisions. Before I hit the buy now button I thought I might ask some personal opinions of people that use the forums and what they use.
Im not trying to get mean here but when I stop at a gas station for directions I dont want to be pointed at the rack of maps and told to go use them, I want a personal favor from the guy/girl behind the counter that lives there.
thx for the help from those of u that did. I guess ima go with TY 8x +R's to get the faster speed.
thx again guys
Leoslocks wrote
DVD+R media can be played back if you use the BITSETTING to burn the disc. to enable BITSETTING on the 708a drive one will need to use PLEXTOOLS from version 2.17, firmware 1.08 and any NERO BURN version from 6.3.1.25.+R's burned in the 708A will not play in the house Panasonic DVD/VHS player.
by enabling BITSETTING on the DVD+R media the Panasonic standalone dvd players that are manufactured not to play them back now can because of the BITSETTING. i've tested discs burned with bitsetting enabled and they work in the Panasonic dvd players old models as well as new ones.
How poetic. Business is business.Originally Posted by krupted
Anyway most new dvd players play any disc anyway. -
mattyboy wrote
your're incorrect about that because some of the newer panasonic and jvc dvd players will only playback DVD-R media.Anyway most new dvd players play any disc anyway.
Thanks, I am downloading 2.19A as I type. Seems a new version was just posted (1/20/05).Originally Posted by budz
+R media is not even recognized in a JVC SR-MV30.
In older burners, +R was quicker to utilize higher burn speeds. Not much of an issue any more. -
V 2.19 will not install. It aborts after not finding PlexTools installed.
I will try downloading 2.17. If that doesnt work, I may try one of the older versions and updating with 2.17/2.19
What am I missing here?
A question about Taiyo Yuden.
By wtsinnc in forum MediaReplies: 18Last Post: 13th Jan 2013, 05:03 -
BDR-206 and Taiyo Yuden
By ccarag in forum DVD & Blu-ray WritersReplies: 20Last Post: 2nd Oct 2011, 12:54 -
Taiyo Yuden DVD-R's (In Australia)
By SE14man in forum Newbie / General discussionsReplies: 0Last Post: 20th Jun 2011, 04:21 -
Bad Taiyo Yuden discs
By StrobeLightEpileptic in forum MediaReplies: 61Last Post: 2nd Jan 2010, 19:30 -
Taiyo Yuden DVD-R - Thanks
By casual-dvduser in forum MediaReplies: 3Last Post: 6th Jun 2007, 03:59
