Hey guys. I have two questions.
First, does anyone have any experience or opinions on which encoder has the best noise filter for low res avi caps. The resolution of the avi files are approx 320 x 240, and are divx/xvid compressed.
I've heard that TMPG has a great noise filter, but I know it is slow. I can also use Convolution3D with avisnyth and frameserve to CCE SP, which would be faster. I probably will run some tests myself, but I was wondering if anyone has any opinions on which noise filter is better.
Second, I have been debating on whether or not to encode these at Half d1 (352 x 480) or use the lower but DVD-compliant 352 x 240. I know the lower res is closer to the original resolution, but I am worried about compatibility. FullD1 being the most compatible, I think I have read that HalfD1 is usually ok, and that 352 x 240 might have some compatibility problems in older players even though it is compliant.
Does anyone have any experience encoding in 352 x 240 and have your DVDs all been compatible?
Thanks in advance.
PIV 2.26 GHZ
512 MB RAM
MSI Geforece 3 128DDR (S-VIDEO IN)
WD 120 GB 7200 RPM H.D.
WINDOWS XP SP2 -
I would filter it in virtualdub, and frameserve it at 352x240. I've had no compatibility problems with MY dvd players, but you're right, some older ones may balk.
Cheers, Jim
My DVDLab Guides
Low res in Text presentation
By jairovital in forum EditingReplies: 5Last Post: 4th Aug 2010, 17:31 -
DVD Studio Pro -select Video, Audio and Subtitle track in low res for proof
By RonCole in forum MacReplies: 3Last Post: 3rd May 2010, 12:03 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29 -
CCE, MP4 and AviSynth Error
By Maikeru-sama in forum Video ConversionReplies: 28Last Post: 11th Jun 2008, 04:24 -
25fps AVI > NTSC DVD - am I doing this right? (AviSynth, CCE, DGPulldown
By fischkopf in forum Video ConversionReplies: 25Last Post: 22nd May 2008, 19:31
