Read a topic that LG GSA 4040B had a hard time burning Ritek G05 at 4x. Can someone confirm this? Or can some one confirm that there is no problems?
Was considering to buy Printables DVD-r, anyone that can give me a tips what will work good with LG GSA 4040B?
I have had the problem with 3 different lg drives, They don't work well with the Riteks.
Switched to Tai Yuden disks and so far 50 out of 50 are perfect. -
I have noticed slower burning on some brands with this burner also.Originally Posted by jeryray
Where is this topic you mentioned? I would like to read it.
Jeff -
So far, 8X media I've tried on my 4040B
TY02 burned at 4X
MXLRG03 burned at 4X
Ritek G05 burned at 2X
ProdiscF01 burned at 2X
It seems that the cheaper 4X media burns at only 2X with this burner also. Burned a ton of Ritek G04s succesfully with this burner though. -
Do you have the latest firmware or which firmware do you have? Also have you tried more then one sort of Ritek G05? Did you have good results even thue they only burnt at x2?Originally Posted by matthewmalay
I know you didn't ask me, but its a free forum. Yes, the discs burnt at X2 only played well. And yes, firmware is latest. This burner is picky about which discs it will hbrun at 4X. That is all there is to it.Originally Posted by Espen
Thanks,
Jeff -
Thx for your respons. This means there is no reason at all to buy G05? I mean in fact you should stay away from them if they only burn in x2. But is it the same for all G05?Originally Posted by hiptune
I got an lg gsa-4160b what should buy i? ridata g05 8x or ritek g04 4x? thanks in advance
Ritek RiData G05 vs RiData Pro Series - Anyone know the difference?
By DVantrease in forum MediaReplies: 5Last Post: 1st Jan 2009, 16:48 -
lg gsa-4120b dvdwriter
By mustang1967 in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jun 2008, 00:50 -
Drive problem- LG GSA-H10L
By pinetop in forum ComputerReplies: 9Last Post: 17th Apr 2008, 02:39 -
LG GSA-H22N misidentifies RW media
By Overwind in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Aug 2007, 14:54 -
Cant update my LG GSA-55L firmware?
By kiaconcepts in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th Jul 2007, 08:59
